dimmer switch voltage control??
2.3turbo
I know this question makes me sound like a red neck,But here goes anyway
I keep blowing out diaphrams on the adjustable pressure switch on the surflo
I was wondering (until I get money for a progressive controller) can I just bypass the pressure switch on the pump and use a dimmer switch to control the voltage to the pump,Or should i just bypass the pressure switch and use the appropriate nozzel size . Right now I have a 15 nozzel and with the pump maxed out the engine can't take it ,So i figured if i turned down the voltage to the pump it would work?
Not sure if the dimmer sw. would handle the current to the pump but if I had to guess i'd think it might be able to do it. Interesting idea. I like it when people try something different. We all know there are some terrific kits out there that are proven to work-but its fun to experiment so long as you don't blow anything up. I think some of us Buick guys like doing things the hard way sometimes because we like a challange-otherwise we'd all just drive Chebbies. :wink:
I don't understand why you have had a problem with the pressure switches though. Can't help you too much today cause I'm pretty well doped up cause I threw my back out a couple of days ago. Had to have an ambulance come get me . I'm like the 130 yr old man. :eek: Now I can just go into la la land and daydream about my Buick. To hell with everything else.
Current capability of the switch is the question 1, then comes with voltage drop across it as the pressure/amperage on the pump increases.
I=E/R
I=current
E=voltage
R=resistance
A heavier duty variable resistor may band aid it.. and the smaller the motor's displacement.. the more delivery becomes a concern.
Turn down pressure, increase your turnon point.. and watch that it doesnt knock.
How about the dimmer rheostats on the dashboard for the DC dash lamps?
HTH
A variable power resistor works just fine. :)
I like the 100 watt surplus versions. About $5. :cool:
