remove tires and drums
remove cover (1/2 - 13mm)
remove carrier pin lock bolt (5/16 - 8mm)
remove large carrier pin (slides out )
push axle in and retreive c clips from axle ends with a magnetic pickup pull axles back a few inches
easier to do out of car but can be done in car , up to you, if you remove carrier mark the caps so they reinstall as you removed and note shims so they go back where they were
rotate and remove spider gear and spider thrust washer (keep them together)
knock the S spring in a little rotate carrier 180 , pull spring out
remove the side gear and clutches /plates and shim that are behind them
replace with new clutches plates and shims (same as you removed them) and reinstall side gear into carrier
do same for other side
put spiders and thrust washers back
tap S spring back in ( vise grip tongs make it easier)
push axles in and reinstall c-clips ,pull axles back , install large carrier pin back and retainer bolt
put cover back on
remove plug at passengerside front side of pumkin (3/8 drive extension)
fill with oil and posi lube pack, replace plug
replace drums and tires
