If you want to just DO IT.
Then you can use a simple voltage divider, and log it into the original O2 pin.
What you CAN do.
I build a voltage divider.
----From WB -------^^^^------- Out -----^^^^--------II>>
10K 2K Ground
1/8 th watt 1/8 watt
10K meaning 10K resistor.
2K meaning 2K resistor.
Out means to oem O2
I tried talking Ken Chu into including the option of something like this input into DS but that didn't work.
It'll be off screen but you can at least read it.
I'm no EE, Jim, and the lithium crystals may not hold up, but we're giving ya 103%, Capt'n.
There is another thread running about WBs, and at the one site they showed an AFR meter that worked with some other WB, If it's a 0-5v output might be close enough to get you into good neighborhood readings.
