door insulation
STAGE 2
3rd and long
Ive installed window kits and all new w/stripping, but both my water shield (piece of brown paper taped to the indide of the door) and insulation are toast. I can always make a new paper, but does anybody know where I can find new insulation. I dont want dynamat or anything spray on. I'm looking for OEM or something close.
I use a heavy trash bag and duck tape to replace the paper barrier. You can by the material they use for the "tick" liner (the heavy pad) at most upholstry shops. All it does is insulate noise and rattles so you couls probably use a really dense foam (same thickness as original) as well.
