Door seals, upper & trim??
87we410877
See the attached pictures. I am looking for the flat seals that go between the trim and the body on the upper doors and also the upper window seal that secures over the trim. Where can I find all this stuff? Thanks!!
Roof rail seals they are called.
I need quality seals. I bought lower door seals from cars.com and they don’t have the plastic reinforcement on the ends or inside where the white push pins go into the door. They ripped apart upon installation.
Whose got the good stuff?? Highway stars?
Thanks!
10/4 the roof rail seals / GM ones are $$$$ if you can find them and the soft seal brand ones are discontinued / its a crap shoot with the other ones I have no experience with the ones other vendors have
I hate these cars!!!! Damnit!!
classic industries have them as well as g body and opgi, kirbans has them as well and they probably have done more real world testing on our cars than others, I bought the moon roof weather strip from them it been on my car for almost a year now and doing ok
Any idea if the Gbodyparts lower seals have the plastic in the ends and along the length of the seal like the originals?
Gm is the only seal with the nylon reinforcements.
Sent from my SM-G960U using Tapatalk
Why the F even make them then? It’s like making reproduction Goodyear eagle GT’s but without the belts in the tire. “oh these are just rubber tires you can’t actually use them” seriously. Is it that fucking hard to put the extra two percent effort in after going so far as to reproduce the entire seal? The molds, the material everything. Pisses me the F off that we put so much time and effort into our work only to get scammed into buying CRAP that doesn’t work, falls apart, or is just complete garbage.
Bought a brake booster gasket from g body I think it was and this thing was like 1/8” thick and made of the cheapest thinnest foam that an ant could devour in minutes. The factory one is thick nice rubbery gasket. But hey, people will buy it right? Assholes.
