Can someone send me a DS file from a stock chipped car that is not running when the log is started..... then the car is cranked ... and idling....
Mine died.... and I am trying to see what is the problem. I suspect.... the crank sensor.... or cam sensor..... or coil module..... but I am not sure. It has no stored codes..... It just died while I was gassing on it near the house.... I see the injector pulse width coming up some.... like 9ms while I am trying to crank..... but the spark advance is at 0 deg..... I am not sure if it is supposed to have advance while cranking or not....... that is why I need to study on someone elses logs.....
Can someone help me?
bdykes@beabulldog.com
