F
Fred 86 GN
Guest
During a run, this happens 2-3 times, typically around 4200-4400 rpm, in second and third gear mostly. The A/F ratio drops below 9:1 on the DS screen (what the ECM is calling for, supposedly), and the next half-dozen frames show the following KR amounts -- 1.8, 1.2, 0.9, 0.6, 0.3. Sometimes it only gets part way down then starts again -- 1.8, 1.2, 1.8, 1.2, 0.9, 0.6, 0.3. Sometimes the 1.8 value causes a "knock count", sometimes not. So I only see 1-3 "knock counts" in a run typically.
Does not seem to occur during shifts (those happen around 5000rpm and the engine falls back to 4000rpm or so).
Anyone else see this sequence?
Should I be concerned?
O2's can be 760 to 820mV during this event...doesn't seem to matter.
Thanks,
Thanks,
