DUAL FAN ASSEMBLY
J-B Racing
Forced Induction
Can anyone remember from which company Fan assembly will fit with little modds. I had bought one off a fellow who passed away a while ago and he had mentioned it was off a Chrysler sedan.
trying to get one for a car I am working on and I can't put my finger on it.
Joe
Dodge Intrepid, 1998-2004. Just have to cut the ears off and it sandwiches in between the radiator tanks.
Additionally I've made a bottom bracket that holds the fan high in the radiator space and allows the bottom tabs of the top radiator plate to hold the top of the fan in place as well. Check for them on Ebay, Kirbans and GBody Parts.
Thanks for confirming. But what Bracket are you talking about. The one off the stock Fan
The Intrepid fans use the bottom bracket that the GNMan is talking about. Saves you alot of time and frustration installing the fans.
I am a parts manager so I can get a Dorman 620-005 which is the same that Kirban has on his site.
If I remember I used the lower bracket of the stock fan
Thanks guys for the quick response. always a pleasure to still be on this site after so many years....:)
A lot of guys do use the stock bracket so mount the lower side of the fans. Trouble with this is it leaves an ugly amount of gap (and bare radiator showing) at the top between the bottom of the top hold down plate and the top of the fan. The bracket I made holds the fan high in the space.
Or search for them on ebay.
Joe,
Here’s how I mounted my Intrepid Dual fans
Had these powder coated after the mock up
