Originally posted by Craig Smith
Low side.
Be careful with what you are connecting the unit to. We have found that the current design of the eDist does not provide adequate heat dissipation to drive most ignition coils and the drivers will unsolder themselves from the board if you try. The solution has been to feed a DIS-4 with the eDist outputs and have the DIS-4 run the coils.
We are currently testing a new design that should take care of this problem.
