The straightest, smoothest shot of air to the turbo will yeild the best results with the least restriction. Try to have as few bends as possible. Pay attention to all adapters and transitions, as to have the smoothest flow possible. Blunt edges and tapers from Home Depot plumbing fixtures/adapters, 90* bends, and poorly designed filters all disturb/inhibit air flow. I run a 3 piece an "Intense Performance" air filter w/ inverted cone end, and a exchangable gentle taper filter to intake tube transition, and leave the filter under the hood.This filter will flow 1300cfm. I have designed a heat shield to deflect as much heat as possible from the filter area, and feed outside air to the filter thru 5" ducting. Can't say it's the best way to go, but I did alot of research and brain picking last year, and came up with what I run now. Thru the years, I have used Kenne Bell, and other cold air set ups, and my design is an improvement over all of them. Tried posting some pics, but they won't reduce enough. If I can, I will try again this eve. Brian
