corsair231
- Jul 8, 2005
Hey guys, not a Buick specific problem but a general electronics question. Can a magnetic field travel via a wire? I know, it's an off the wall question but let me explain why I'm asking.
The particular vehicle I'm dealing with is a 1st gen Dakota v-8 pick up. Situation is I had a leaky intake gasket. Pretty straight forward r&r job. I finished the install, hooked my harness back up and started the truck to check everything out. My factory temp gauge started off like it should on cold and as the truck warmed up it went up the scale as expected. The problem is it never stopped. The truck was not running hot but the needle slowly climbed all the way past the hot mark and proceeded to bury itself at the bottom of the dial and would not come back. I though I may have just stuck my needle so I took the cluster apart and the needle moves freely but went back to hot as soon as I turned the ignition on. I happened to have another cluster so I changed it out and the temp gauge did the same thing.
I then figured I had either pinched a wire or left a ground off. I double checked and have checked several times now and cannot find either. The switch is a simple open switch that grounds as the temp rises. It appears to be operating properly. I unhooked the harness from the switch and started the truck. The needle swung all the way to the cold side of the gauge and buried itself at the bottom. The factory check is to unplug the harness and the gauge should read cold. Ground the plug and the gauge should read hot. It will not move no matter what I try. The rest of the gauges seem to work properly.
The only thing I found out of the way with the wiring is the wire from the switch was running right behind the alternator and touching the housing at the center where the magnetic field is created. I know an electrical charge passed through a wire winding around a iron nail will create a magnetic field but is it possible the magnetic field from the alternator has traveled through the harness and somehow polarized my temperature gauge? I had touched nothing in the dash before this problem manifested and I can't find any wiring problems so I'm at a loss as to why my temp gauge won't work. Ideas?
TIA
TIA
