Engine Filter
jpratt
If I remove the oil cooler adapter, what size filter will fit? I am looking at running engine for a little while with no cooler on.
The same one's you regularly use.
Is it possible to remove oil cooler adapter while motor is in car? I remved the PTE turbo save and started to remove the cooler adapter but it looks like it whill hit the frame rail, nipples. I had to stop working on it tonight because I did not have anything to turn the adapter with.
Nevermiond I am a moron. I do not know what I was thinking. The adapter does not screw off the holder in the middle unscrews and that is what holds it together.
DUH
Will a biggie oil filter adapter work without the oil cooler adapter?
