MY TTA has been running fine up til a couple of days ago. Boost is set to 14 lbs and pulled strong.
When I drove it yesterday and today, it misses like crazy when, from a roll, I go to WOT. When the boost kicks in and when it reaches around 5 lbs it misses and bucks. The boost maxes out at around 10 even though the actuator is set to 14. It shifts at around 4000 rpms. On my scanmaster, there are no codes, I do a recall on the scanmaster and the O2 is around 880 and O knock At idle my BL is 138 and my TPS is .42 My fuel pressure with line off is 42.
I checked the three hoses on to the turbo, the PVC line. I am running 93 octane with a couple of gallons of 104.
Any idea what to check next ?
