20 bolt oil pan 140 engine code standard bore block with oil drain return punched in the front $100.00. 2 dot rods on stock bore turbo pistons $50.00. 8445 stock heads with fresh valve job, valve springs, rockers, & stock gn valve covers (non ported) ran for less than 1000 miles with no smoking $150.00. 20/20 turbo crank $40.00. Good used cam sensor $40.00. Used front cover $20.00. Stock uncut turbo shield $30.00. New set of 20 OEM stainless 86-87 t type/turbo t metric lugnuts $25.00. 87 turbo regal analog gauge cluster with working speedo, tach, boost gauge, fuel , & idiot lights. 11,482 miles shows on odometer. $60.00.
