- Jun 6, 2001
I found this interesting:
This is a Mopar race block, notice the lines from the heads at the front and rear all gather under the thermostat. So with this arrangement the coolant that hits the rear part of the cylinder heads doesn't have to travel all the way to the front part of the head to try and cool those with the hot coolant from the back. Seems like a stage engine could be setup the same way.
I was also watching a 340 build today being built as a 2000 hp twin turbo, the engine builder had an external oil drain line tapped into the middle outside of each head straight down to the oil pan to assist in draining all the oil in the heads. Since the Buick V6 heads are at such a steep angle, giving that oil that collects in the head an extra path to the pan seems like a good idea. Just wondering if the stage racers on this board have tried either of these methods?
Mike
Mike
