alright.. i have been wondering why i (having a hotair that is) cant run as much propane as anyone else..
i know i know i have a stock'ish car that only ran 13.6's before.. so lower hp is one of the factors..
but im saying i have to turn it WAY down.. the duty cycle knob is below 15%, i have a "60" jet in there
bottle pressure is below 100psi, i need a refill.... if i got a refill i would probably have to turn the boost even farther down.
SOOOO here is my theory..
propane is heavier than air right?
Propane
Molecular weight : 44.096 g/mol
Oxygen (i think this is pure oxygen.. so the air we breathe would be heavier due to having nitrogen and whatever else in it, right?
Molecular weight : 31.9988 g/mol
so, my turbo is spinning 100,000rpm and all of a sudden a substance that is 1.37 times denser hits the blades and slows them down..
is the extra 12.098g/mol enough to matter when it comes to a turbo spinning at a hundred thousand rpm or so?
ALSO
i know the kit has a jet in it.. but you guys have your.. well lets use 100 psi i guess, so, 100psi bottle pressure working against say 25psi... so that brings the effective pressure down to 75psi
mine is in the intake path before the turbo.. so i have 100psi bottle pressure working against a HUGE AMOUNT OF VACUUM.... well i dont know how to measure it w/o another boost gauge but im gonna ASSume its far enough on the opposite side of the spectrum from 25psi to make a difference..
thoughts... ideas.. help? anyone?
Propane
ALSO
