dproberts05
- Oct 12, 2005
This car is second to none in quality and appearance. Won 1st place at 2006 Norwalk Buick car show in modified class. Everything done with extreme detail. 86 WH1 with 71,XXX with 1000 on newly redone engine and trans. Almost everything is new. No power options(weighs 3440 with me in it) The car is in pristine shape inside and out, show quality. Also has plenty of horsepower provided by good parts. It will also include every original part, nut, bolt, etc. except for the stock turbo and bumpers. Price at bottom
Engine:
SG1 block stock crank .10/.10
JE pistons .20 over
Clevite 77 bearings
Billet main caps
ARP head and main studs
Speed-Pro file to fit rings
Cloyes roller timing chain and gears
JB Racing ported and polished heads 1.71 intake and 1.56 exhaust
Ported and polished intake with RJC powerplate, Kenne bell 70mm tb and plenum
Balanced rotating assembly
Comp. 212 hydraulic flat tappet and lifters
Rollerized cam button
Hardened chromoly pushrods and FTS hardned rocker shafts
New FTS HV front cover
HR poly motor mounts
Terry Houston SS downpipe with dump
New heavy duty water pump, new radiator
Precision TE62 turbo
Translator w/ new LS1 sensor
Plus plenty more
Fuel:
ATR double pumper with primary pump wired to Kenne Bell Boost-a-Pump, 2nd pump turns on at 12psi, Accufab adjus. reg. 60lb/hr injectors, PAC alky kit, turbotweak alky chip
Trans:
Original BRF built by Brian Hofer with 9.5" l/u, B&M supercooler
Interior:
The interior is in perfect condition with no issues. Speedo converted to 145mph, new headliner, autometer sport comp2 boost 30Hg-30psi, oil press, water temp, volts, caspers knock guage, autometer pro-comp liquid filled fuel press. guage mounted on hood, ashtray switch panel
Exterior:
Paint is around 5 yrs. old and is Sikkens mercades black and is perfect, car has fiberglass bumpers. trunk braces, underhood braces, front frame braces, front end lowered 1", factory G80 rear with finned alum. cover, factory spoiler, new seals, weatherstrips, etc.
I know the grey paint is missing, the owner at the time thought the grey was ugly.
I'm sure I am forgetting to include plenty, this is a turbo regal that stands out amongst others for it beauty. I have plenty of pictures taken in my garage, and I will take more outside once I clear some snow. I'm asking $20,000 or make and offer, serious interest only please e-mail at dproberts05@aol.com or 269-625-5553
Engine:
JE pistons .20 over
Clevite 77 bearings
Billet main caps
Plus plenty more
Fuel:
Trans:
Interior:
Exterior:
