Details on car......
NEW parts....installed less than 3000 miles ago.
PT&E front mount cooler
TA-49 Turbo and Billet inlet bell
Cotton fuel rail and adj. fuel pres. reg.
Flowed and calibrated Green Stripe injectors
Boost gauge and Knock detector in A pillar pod
Roller timing set and 110lb valve springs.
Connely "Mini-Mag" chip w/3 oyhers that came with the car.
Plug wires,IAC motor,plugs,160 deg. thermo.,stock MAF,Sears battery.
Terry Houston S.S. 3" downpipe and adj.wastegate. S.S. cat. eliminator with dump.Bowling Green Customs S.S. dual 2 1/2" mandrel bent system with Flowmasters......sounds sweet and Mean at the same time!
Lifetime Midas brakes
Shocks all around.
COAN lock-up 26-2800 stall Street/Strip Converter
COAN re-built stock trans, built with best of Heavy Duty everything.This is a
QUALITY trans/converter combo and shifts great.
Front steering centerlink and Midas alignment.
Digital dash conversion to read above 85mph.
Perfect fit driveshaft loop.
AC system conversion to R-134a
Brakes correctly converted to vacum set-up....car stops great.
I'm sure i am forgetting a few new parts(oil change,filter and grease job).
Interior is nearly perfect with NO rips or tears or sun fading.Headliner was recently re-done and looks perfect.Power windows work great and do not rattle...has tint-film that can be removed.Steering wheel needs re-dyeing and has beautiful centercap.Digital dash reads bright clear and perfect.Carpet and savers are good also.I am going to up-grade the radio to a correct AM/FM Tape Grapic Equilizer radio befoe i take it to Auburn in a week or so.Very little wind noise at speed.If you are picky about your car's interior...i am sure this will pass your inspection.
Body is RUST-FREE with original paint. It is presentable and might have wonders done on it by a good shop that can do small stone chips well.
Thats this car's ONLY major problem.Looks perfect at night
Well documented with verifiable mileage.All past owner info is available and all paperwork for warranties and parts reciepts are in a folder that's been with the car for years. This car has been really well cared for and has been garaged all it's life.
Call for more details or requests for specific shots of car.
Peace WildBill
