SignUp Now!Originally posted by volvoman
is there not a gasket I can buy to just put in there? I thought that someone sold somthing like that. I just don't want to take it apart so close to ttv. I missed it last year and I am not going to miss it this year. I will be there if I have to push my car down the track..
So, I used a 8" bench grinder hard wheel. I pulled the turbo, it was not that bad just took some time. I thought that I got it pretty flat though. When I started it up it had just a tiny, tiny exhaust leak. I hope the carbon will plug that up. It is at least not as bad as it was before. Thanks for the tip. I will do redo it after the races I think. Do you think that it will effect anything in the performance area that much?
I think I am going to pull it off again for a redo. I am going to wait a bit till it blackens up again. I did think about spraying it with a little paint or a black marker and hitting it again to see if I got it all. One more time should do it I would think.
