Drewster
Wish I Had A Clone. AKA Andrew Youlio
- May 31, 2001
if i pull my 18# spring in the ATR External wastegate and install a 14#, will my chip controled boost levels be less, the same or uncontrolable ?
i need to run between 17-14 psi boost to stay knock free on 91 octane and the chip (92thrasher) wants to run 20-17psi. i have been running 15psi in all gears with a manual check valve set up. it would be nice to to let the chip run 17,16,15,14psi in 1,2,3,4th gears. of course this would be for the street.
would changing to a weaker spring do the trick?
i think it would be like loosening the adjustment rod on a intenal gate. but i dont know for sure.
Andrew
(trying to run less boost.....new for me)
thanks in advance
Andrew
thanks in advance
