f/s '87 long block
KevinB
Testing waters here:
97K miles (I will show you what the car title says and you can see the odometer for yourself). Still in the car...can come and listen to it run.
Comes with:
unopened engine (oil pan to intake)
hemco upper plenum w/t-body
stock headers
stock motor mounts
Does NOT come with:
fuel injectors or rail
cam sensor
turbo drain
turbo
accessory brackets or accessories (water pump does come with it)
coil pack or module
Engine runs great! Has some sort of replacement valve springs (not sure of what they are...but they work good). Car just went 11.3 @ 119.7. Compression test shows it in great shape. Guy before me ran royal purple in it. I run the valvoline synblend stuff.
I am firm on the price.
Don't want to really sell it but can really use the money for my next step with the car. Will not separate. Will not deliver. Zip code is 47025. You can come here, listen to it run, take a ride in the car, then we can spend 2 hours pulling it.
$1200 firm
I put my zip code in the ad, but I'm in southeast Indiana...right outside of Cincinnati Ohio.
bump
I've seen this car in person. Very clean, and sounds very good!
Good luck with sale Kevin.
