Sleeper1987
3.8L of Fun!
- Jun 11, 2006
1987 Buick Turbo-T
RARE color yellow/beige exterior (1 of 160)
tan interior, buckets, console, moonroof, twilight sentinal, concert sound, power windows, posi, 122,000 miles, complete new A/C system (ICE COLD), alternator, battery, Sony AM/FM CD and speakers 15x8,15x5 Weld pro stars w/ 275/60/15 Goodyear eagles rear, 205/75/15 front 8.5 10 bolt 3.42 gear and a tight packed posi.
Mods:
stock block, crank, rods, pistons
turbo saver biggie oil filter relocater -takes large diesel filters
K+N cone filter
ported heads
206/206 cam
LT-1 springs
009 injectors
fuel pump(inline nos hipo same as t-rex vortech)
Red Armstrong volt booster and 93 chip
Casper hot wire
TA-49 turbo
adjustable wastegate and fuel pressure
ATR 3" down pipe
3"test pipe w/dump
Cotton 3" single shot exhaust
front mount intecooler
ramcharger fans
B+M megashifter
NEW BOP turbo 350 with alto clutches and kevlar band
B&M shift kit
TCI saturdaynight special converter
trans cooler
torque strap
comp eng 3 wat adjustable front shocks
kyb gas adjust 50/50's rear
boxed upper and lower rear control arms
RR air bag
polyurethane bushings front and rear
Auto meter tach, oil pressure, water temp, fuel pressure and boost guages
Scanmaster 2.1
FACTORY OPTIONS
AR9 seats, reclining bucket
AU3 power door locks
A01 tinted glass
A31 power windows
A90 power trunk release
BD1 rocker panel moulding trim delete
BS1 acoustical insulation pkg
BV8 ornamintation exterior door lock cylinders
BW3 ornamentation extra roof window trim (painted)
BX5 ornamentation ,exterior moulding roof drip (painted)
B24 side window reveal mouldings (black)
B48 trim package luggage compartment
B71 wheel moulding (colored)
B72 ornamentation ,exterior moulding belt reveal (colored)
B77 ornamentation,exterior moulding w/s reveal (colored)
B79 ornametation,exterior rear end
B88 moulding body side (custom)
B89 ornamentation, exterior moulding,RR window reveal
B91 exterior moulding, door edge gaurd (colored)
B94 ornamentation, exterior emblem ,body,var 1
CD4 windsheild wiper system (pulse)
CF5 roof,sun,glass sliding,elec
C18 arm and blade WSW
C60 HVAC system,air conditioner frt man controls
C95 lamp, intr,roof,courtesy and dual reading
D55 console, frt compt,floor
D64 mirror,l/s,rh,sunshade,illum
D68 mirror o/s,lh&rh,rem cont,painted
D71 gear speedo driven
D85 stripe,body side, lower accent
E5Z speedo adapter delete (analog cluster only)
FE3 suspension system (sport)
GU6 axle rear 3.42 ratio
G80 positraction,limited slip
G87 ring gear 8.50 10 bolt axle
J41 brake system,pwr,frt disc,rr drum,cast iron
J5O brake system power
KO9 generator 120 amp
K34 cruise control automatic,electronic
LC2 ENGINE,gas,6cyl,3.8L,SFI,V6,TURBO,H.O
MW9 Transmission,auto,4spd,THM 200, Conv clutch
MXO merchandised,trans,auto provisions,O/D
NA5 emissions system,federal, tier 0
NP5 steering wheel (leather wrapped)
NQ5 cap steering,wheel,horn,deluxe
N33 steering colum,tilt type
N89 wheel" turbo" aluminum
QYH tire all p215/65r15/n wol r/pe st tl HWY
TL6 Grille (black)
TL8 ornametation ,exterior,hood, (3.8 SFI TURBO)
TT5 headlamps halogen 4
T47 HOOD (TURBO)
T63 headlamp on warning provision system
T82 headlamps auto on/off/cont
T83 headlamps,dr,(special)
T93 lamp,tail&stop (special)
UA6 theft detterant system
UQ1 provisions for stereo
US7 antenna,power,painted radio
UW4 speaker system,6,dual frt dash mtd f/d,dual
U23 cluster,inst,trim odom
VD6 bumper provisions,frt,aluminum
VD7 bumper provisions RR,aluminum
VK3 license plate mounting pkg
WO2 package SPORT APPEARANCE
Y56 merchandising package GRAN TOURING
19A stripe color accent two tone med gray met/black
54U Primary color exterior, MED FLAX (91) YELLOW BEIGE
62B Trim comb, light saddle cloth
62I trim int light saddle (I)
Now for the problems the car has has a poor job of having the door braces removed seats need covers , maybe a headliner later down the road.Has normal dents and dings all over as you would expect with a car this age,the bumper fillers are in good shape, as is the dash pad , Overall condition out of 10 would be a 7 in my opinion. Car runs strong .It ran a 8.19 in the 1/8th with low boost (13psi) and a soft launch so mid 7's if launched harder .Maybe faster Never runs hot.
new/replaced parts added in the past 2 weeks
fan wiring repaired (switch fixed)
fuel filter (new ac delco)
fuel tank cleaned (removed and flushed)
fuel injectors cleaned (pressure cleaned)
oil/filter changed
car cleaned up (weekly)
radio fixed (missing fuse)
gauges fixed (bad connection)
new Turbo 350 (replaced ailing 2004r)
acc boss hogg converter
tci converter (comes with car)
intercooler flushed
intercooler piping cleaned
exhaust manifold gaskets
new delco pcv valve and hose
new coil pack
new autolite 23's
homemade alky kit installed
throttle body cleaned
top engine cleaner
small oil cooler added to turbo feed.
boost controller added
ASKING 10,500 or possible partial /full trade
my e-mail is onerarebuickT@aol.com
Mods:
K+N cone filter
ported heads
206/206 cam
LT-1 springs
009 injectors
Casper hot wire
TA-49 turbo
ATR 3" down pipe
3"test pipe w/dump
ramcharger fans
B+M megashifter
B&M shift kit
trans cooler
torque strap
RR air bag
Scanmaster 2.1
FACTORY OPTIONS
A01 tinted glass
A31 power windows
TL6 Grille (black)
T47 HOOD (TURBO)
oil/filter changed
intercooler flushed
new coil pack
new autolite 23's
top engine cleaner
