Facotry Ignition wiring Question
karolko
Okay i need your help guys,
I am planning on doing some rewiring to the car...Again.
What i plan on doing is builing a new fusepanel from a late model GM (the one with the small fuses)
What i would really like to see is the wiring diagram for the ignition switch along the steering column. I assume that is where the factory fuse panel gets it''s ignition source from.
Also, i remember under the top of the dash on the drivers side is a long narrow plug with a bunch of wires that clip into them individually. I know for sure, that one of those plugs had the power seat plugged into it at one time and another may have been the dome lights. Does anyone know what i am talking about? Is this Constant power or also Switched power.
What i want to do eventually is eliminate my old fuse panel entirely, thus i do not want to tap into the original fuse panel directly, but finds it's source.
Any help would be awesome.
Thanks in advance,
Adrian Karolko
