SignUp Now!i just replaced my stock timing set with an edelbrock. the stock set has a plastic coated gear which was in my opinion a very bad decision by buick. my chain and gears were fine, but my stock 3.8 in my limited shattered the plastic b4 i bought it and whoever replaced the set in it didnt bother to clean the plastic out of the motor just changed oil i guess. the plastic ran through the oil pump and into the crank and blocked oil to some bearings. shortly after i bought it it started knocking and thats how i found out. i wasnt about to leave that stock gear set in my turbo motor im building. What was Buick thinking with that.........all the performance parts on the GN's and a dumb design can screw you motor royally....
Spend the money on a good roll master set.
