turbobeast707
- Mar 7, 2013
failed for High really High HC's,also failed the visual for coolant bypass hose and fuel pressure regulator hope I can find the stock one.. would a stock regulator help with smog and what is the stock fuel pressure set for? I have a TT smog chip for my setup, the only weird thing was that my my scanmaster numbers for my bl and Int were bouncing around when I was driving home from my smog. BL 132-160 and my INT were from 128-134. Have a barely used 3in cat, I replaced all spark plugs recently CR42ts gap set .32, new egr valve was just installed prior to testing, fuel pressure was set to 38 psi car running vacuum line off. any advice what I shold check or look for?
thanks,
Isaac
			thanks,
Isaac
