Gettin Faster
- Aug 27, 2012
I am not sure the make of the gauges. They are all electric the temp goes to a sender on the driver side of the block. The wire color is green and moves when you move the guage.(When checking to see if all the wires are connected). The oil and temp are on the console under the dash. the oil pressure is a brown wire and goes to another sender. I had to replace the temp sensor in the intake to get the fan to turn on. (also replaced the relay thought that was the problem first). Should I replace the high speed relay or just replace the gauges with better ones? I bought this car with these gauges already in the car. The boost gauge doesn't work either but I want to fix the cooling issue first.
