Has anyone done the fan switch mod as described by TTA 1456 (member)? I finally got around to doing it (after a year) and found that if I had the ignition key OFF and the fan "jumper" switch , which runs both fans off of the temperature switch, turned off, then turned the jumper switch on, then the ignition switch off - - the high speed fan (rt,. side) ran forever?. This happened while the engine was "stone cold" (sitting for more that a month) and I was wondering if anyone was having this problem ??? Any help wouln be welcomed. Turbota
P.S. This mod should really help while in city traffic (if i could make it work.....)
