Grand_87_national
I lika... do da cha cha.
- May 1, 2016
Hello all. I have a problem that has presented itself before ... but promptly went away before I could troubleshoot. Now it's back. I have intrepid fans with a nearly new caspers harness and relays, installed by previous owner shortly before I took possession 6 months ago. The fans, at some point during the time it sat dormant for 2 days, decided they needed to turn on and drain my battery. Fan delay relay was removed prior to my ownership. First thing I did, was remove the caspers relay to test it, and it is functioning as it should. Next, I charged the battery, started the car, and quickly checked the coolant temp on the scanmaster. 70* and coming up as it should. So, I'm lost. The scanmaster tells me that the sending unit is giving the ecm the correct signal, yet the fans are energized. I've owned the car for 6 months and it's only done this twice... the first time (3 months ago?) it took care of itself after installing a new optima battery and the fans have worked perfectly since. I'm almost to the point of installing a kill switch in the ash tray enclosure that will kill the power to the relay, but I hate to do that. Is my ecm bad? What could cause this? Thanks in advance!
