Howdy, just wondering what should the ideal A/F ratio under max boost/power be, as well as appx timing. Heres my specs:
2700 lb car
HUGE air to air
VP C16 fuel 83lb injectors
244 CID TA alum block,8.75:1, ported GN1 heads and stock ported intake, Accufab 70mm T/B T70 turbonetics ball brg,.81 exh side,wastegate set to 26 PSI, headers, solid roller 234 @ .050, 574 lift
getting raedy for a maiden voyage, any help would be great. I have a few base tunes to work with.
2700 lb car
HUGE air to air
