L
level
Guest
I installed the unit last year and the car was running very well. However, there seems to be some sort of gremlin in my car.
I took the car to the track this year and it ran fine. I put the car in the garage after driving it home and when I went to start it a few weeks later, it starts blowing black smoke out the tail pipes. I looked at the Actual A/F and it reads in the high 9's low 10's with the same program that use to read in the 11.7's (WOT). I had to reduce the VE table dramatically to lean the car out so it wouldn't foul out the plugs.
I also noticed that the FAST was reading PSI way low at Vac. (around 5 when actual was about 13). I replaced the map sensor and didn't see a change. Frustrated, I borrowed another unit (including the O2) installed my original program and the results were the same. I have to idle around VE of 12-14 to make the car idle. These numbers use to be mid 30's; this trend continues throughout my VE table. Does anyone have any ideas as to what can be causing this?
