FAST XFI 2.002 update
1. TPS Auto cal now has the ability to work with reverse polarity TPS applications.
2. Added a user-programmable Baro correction table for Alpha-N users. Replaces the fixed correction. Handy for N2O applications with a forwared facing, sealed scoop at higher MPH.
3. Added a negative slew rate feature in the Boost Controller.
4. Updated the Traction Control ITC PA Mode table memory function. Bug fix.
5. Added XIM Sync and XIM RPM sensors back.
http://www.fuelairspark.com/Software...t.aspx?prog=13
