My car has been running fine, albeit a little rich, so I took it to the guy who installed the FAST ecm in the car, and he said it was way rich at cruise and light acceleration. I drove while he tuned on the laptop. He pulled alot of fuel out of the ve table. I then dyno'd the car, and put it back on the trailer. It kinda seemed like it might have been missing a little, but not bad. I got home and finally got to drive it a little. It seems to cut out randomly at idle, cruise, and light throttle application. Not neccessarily a "miss" per se, but you can be cruising at 2000 rpms, and its fine, then all of a sudden it hiccups and resumes. It barely stumbles at idle, but just off idle, if you lightly accelerate, it "putts", between 1000 and 2000 rpm. If you give it more throttle, it clears out, but still has that little cut out. if you give it more than half throttle, its fine. I've gone over the ignition, and can't find a problem. it didn't do this until he tuned it, so maybe theres a problem. I hooked up my laptop, and watched the A/F as I drove, and it seemed OK, ranging from 13:1 to 15:1. I didn't like the 15:1, so I added a little fuel till it came down into the 14's. Any thoughts? Sorry for the long post, thanks for your time.
