22lbChevelle
- Jan 14, 2005
So, I'm back home from school and working again on the Chevelle. Got the ECM mounted, the exhaust tied up, other basic stuff that needed to be done.
I took it out for the first drive tonight, to get gas and test how it all runs. The motor runs great and shifts just as it should. First time I got on it the exhaust came undone at one of those slip and tighten connectors (im lucky it didn't hit the ground and catapult me), but anyways I got that fixed. Then just about 1/4 mile from getting home I notice the lights getting real dim (yea I test drove it at night lol) and then she died. Had to call my dad and have him bring a battery down.
Turns out the alternator isn't charging. The second I got home I put a voltage tester on the brown alternator wire and its not getting voltage.
SO, my question is, since I have 12v from the Chevelle's check engine light running to pin "C" on the C437 connector, should the brown alternator wire be getting voltage? Or should I run the alternator it's own key-on 12v wire??
P.s., for those who read the VSS thread, yea it is kicking out a malfunction code 24 for not having a VSS.
P.s.s., Yes the check engine light came on when the malfunction code was thrown, so plugging the wire into the pin "C" does at least serve that purpose.
Long, I know, but any help is greatly appreciated!
Thanks, Dan
Thanks, Dan
