I have a totally stock 87 GN w/40k miles and the seemingly common stumble problem in two conditions. #1 occasional stumble/driveline jerk at highway speed 70-75. #2 Serious stumble with excessive driveline jerk coming off idle until I can get the engine up to about 2000 rpm, then it is generally fine. Much worse hot than cold. Nearly impossible to drive hot.
What should I be checking? I searched for vacuum leaks, nothing visible and no rev changes using a propane torch (off) gently moved about the top of the engine. MAF sensor is spotless as is the screen. Throttle body and stainless inlet pipe are clean.
When the stumble is not present the car accelerates very smoothly and I have never felt a miss/stumble under boost.
Appreciate any advice you may have. After 27 years I have to believe we have figured out the cause of this GN stumble issue
Thks
JIm
Thks
JIm
