Fluid Capacity of 8.5" Rear?
RKHiPerformance
Turbocharged Sex Cylinder
Can someone please confirm the fluid capacity of the 8.5" rear axle assembly? Does this capacity change significantly with the installation of a T/A Performance diff cover?
Thanks!
2 quarts of gear oil and 4 oz. of gm posi additive should do the trick...
fill it till it can't be filled anymore. That is the reasoning for the position of the fill hole.
