BlackBeauty
- Dec 15, 2001
I have a question. In the instructions, it tells you that if there isn't 2" clearance between the exhaust piping and the spring, to loosen the clamp and move the exhaust over
and install the heat shields. With my Hooker cat-back, I looked and there is about 2cm clearance, definitely not 2 inches. And there is a lot of area that is that close to the spring. Did you all install the heatshields? Like I said, they probably won't even help, because the exhaust goes up, curves above the rear axle, then comes down, the whole time it's close to the rear springs. Lookin' for what others have done... thanks.
