Found, '84 Buick Riviera? motor
dmarx
This motor has no wiring with it. It was cut out of the car before being crushed. What major issues am I up against for this to be a stand alone motor in a streetrod. Will need all electronic,. ECM, and sensors. What is readily available?
Dan Marx
1928 Essex w/'79 turbo
Dan, a standalone efi system will be needed to run it.
Cheapest option & Probably most work: Stock harness and computer to run it, will be hard to find.
Stand alone systems that are not plug and play:
Holly EFI
AEM infinity
Spitronics.
The other systems on the market require a factory harness or a plug and play adapter I believe.
ECUGN
FAST XFI
Megasquirt3 Amp/Efi MS3 ETC
A lot of the turbo Riv parts are different than the rear wheel drive turbo parts. Virtually nothing except the long block can be used. I think the oil pan is even different.
