scot w.
GNSperformance.com
- Feb 19, 2005
*********************Info on the Motor ***************
*New Stage 2 on-center #153 virgin Block Standard never been run!!
*Standard/Standard BMS 3.625 steel Crank
*6.50 in Corrillo Rods
*JE pistons
*Stage 2 Iron Heads
*Stage 2 Intake
*Precision dog house
*Comp Cams Roller Camshaft by Dan Strezo, grind for a Twin Turbo set up! *Roller rockers, and valve covers
*BHJ Balancer
*JW flywheel,
*Duttwieler External oiling system,
*New front timming cover
*Oil pan has the fittings already installed for the oil drain back for
Twin Turbo,s also has the big fitting for the Duttwieler oiling system in the
pan.
This motor is assembled accept for the intake. Intake has been milled for
perfect fit. The fuel rails have been drilled for the injectors but not for the
fittings on the ends. The Motor was built at Faerman Racing Engines in Houston
about 3 1/2 years ago and has been setting on the engine stand wraped in
visquine the total time.
Reason for selling is going in a different direction.
10,600.00 Firm
More info call Puddin @ 865-293-2606 or Earl Howe @ 936-203-0591
*JE pistons
*Stage 2 Iron Heads
*Stage 2 Intake
*BHJ Balancer
*JW flywheel,
pan.
10,600.00 Firm
