Front Brake UPgrade
TEST MY 6
OK OK I know this has been covered a zillion times and I have read about B body spindles and such ,BUT my car has G body drop spindles and I would like to retain them. Is there any other brake upgrade that will work with this without having to go to new spindles??
Originally posted by TEST MY 6
OK OK I know this has been covered a zillion times and I have read about B body spindles and such, BUT my car has G body drop spindles and I would like to retain them. Is there any other brake upgrade that will work with this without having to go to new spindles??
You can send your spindles to BAER and they will machine them to accept brackets for their larger brakes 12" and up. I have this set up on my Pontiac 2+2 (std G-body spindles).
There are a few other aftermarket kits that do similar things.
You really can't go to a larger rotor without modifying the spindle in some way, however.
Do you remember about how much it costs and did you purchase a whole setup from them? Thanks for the info I have a place to start now.
