front brakes keep sticking.i have replaced the calper pad rotors is it the popr . vavle was thinking og going to a larger rotor and calper just not now just didi all the brakes 2 months it dosent lock up all the time if i hit hard they stick or when i use the line lock . i had they same promble be for i put in the lock it dose not do this all the time . and smoke the rotors if i let sit for a while it works fine . was reading some other post where they t off the front and put adjusable for the rear is that the way to go or is my msater cyl. going bad i still run the hydroboost brake could use some HELP ON THE FRONT BRAKES AND WHT JUNK YARD SWAP FOR THE BIGGER ROTORS AND CALIPER I HAVE 17 INH RIMS THANKS CK
