Front Seal part number
Brandon706
Does anybody know the correct part number for the front seal? There is three different ones at advance auto parts? Thanks
Looks like this
If you are blowing it out you might consider drilling out the fluid return hole in the pump(yes you will need to remove the pump) and putting in some hard rings, a stiffer slide spring and a hardened stator support while you have it apart.
One of these won't hurt either.
