Having some troubles here. Installed a PaRacing K member and Spohn tublar a-arms w/ spohn front end rebuild kit. Put everything together and now I can't turn my wheel more than 1/4 of the way without the tires rubbing. I notice something wasn't right with the k member the way it was built didn't look right (Bar was A LOT lower than the oil pan and other flaws) so we took it out and left the spohn a arms on...but still had the same problem. What would cause this? Are the a arms to short or something and pulling the tires in close enough to where they rub? I am going to put the stock a arms back in and see what happens. Would the front end rebuild kit effect this at all? Any help would be appreciated. Just want to get this front end done so I can finish the car. Or is there a way to adjust the a arms?
These are the same tires that I had before and I could easly move the wheel from lock to lock without any rubbing.
