FrontSway Bar
Jeff Strube
I have a 97 Regal GS with a swaybar that broke on the Driverside.
The Link on the driverside lower control arm is the only thing holding it together.
You broke the swaybar? wow! Time for a new one. I'm running the GMPP swaybar kit on my 98 GS. That front one is fun to install. :rolleyes:
How did you break it?
The swaybar is hollow. Moisture, debris, and rust get in between the bushing and swaybar causing it to get weak. This is a common problem. Contact Ed Morad GTPED@msn.com to see if he has a used one in good condition.
