WEll, I got my new adjustable FPR from accufab installed today. The little instruction sheet that came with it reccomended 42 psi (with vacuum line off) and said it should drop about 10 PSI with the vacuum line back on. I set mine at 42 PSI static, and when I put my vacuum line back on, my fuel rpessure only drops about 4 PSI. I was wondering if this is normal, if not, how big of a deal is it, and what I should do to get it right. Also, what are some of you guys running fuel pressure-wise, or what would you reccomend? MY car is a pretty much stock hot-air, I've got a walbro 340 and hotwire kit, and '87 coil, but so far as i know everyhting else is stock (i'm jsut kind of assuming the injectors and chip etc. are). Thanks for the help!
