This is a liquid filled mechanical fuel pressue gauge for a 86-87 Turbo Buick or TTA. I bought it from Kirbans for 35.95 plus shipping. Brand new in box.If you need to see a pic go to Kirbins website. Here is the discription.
1984-1987 Turbo Regal -
Liquid-Filled Mechanical EFI FUEL PRESSURE GAUGE KIT
This mechanical EFI fuel pressure gauge reads up to 100 psi and comes complete with attaching adapter. It’s manufactured by Marshall and made in the U.S.A.
The adapter is CNC-machined for precision fit and leak-free performance. It attaches directly to the schrader valve outlet on the factory GM fuel rail.
The front side of the fitting accepts a standard 1/8″ NPT fitting, which matches the outlet on the very distinctive engine-turned face, liquid-filled 1-1/2″ fuel pressure gauge. The gauge is liquid-filled to reduce needle vibrations, insure accuracy, and is very durable.
Now you can tell if you have a fuel problem by simply checking the fuel gauge at the end of the fuel rail. It’s small, so it doesn’t interfere with any under-the-hood modifications.
This kit is easy to install and adds a high-performance look under the hood.
7197 1984-1987 Turbo Regal - Liquid-Filled Mechanical EFI Fuel Pressure Gauge Kit
30.00 shipped.
paypal preferred. Thanks AJ
30.00 shipped.
