I need help from anyone out there
I have a 85 GN that has a fuel pressure problem, if I adjust the pressure at 45 line off, at WOT the fuel pressure gauge does not go past the 45 psi's no matter how much boost is there. But if I set it at about 60 at WOT and 17 pounds of boost the gauge will give me a reading of 60+17=77. Could it be that the gauge or the fuel pressure regulator is no good. The car seems to run very strong and I can hear some minor knock. What do you think that a vehicle with these modifications should run in the 1/4. I do not have a Scan Master YET, I will also get an 86 or 87 MAF. How would a Blue Holley external fuel pump would do compared to the Walboro 340. I just don't like to be embarrassed by the Mustangs or Vets on the streets. Daily driver
Enhanced turbo
160 Stat
3 inch UP & DOWN Pipe
3 inch dual flowmasters with 3 inch tubing
390 gears
Home ported heads
Cool air induction 12 inch K&N
Blue Tops
93 Postons Chip
Postons High Performance Overhaul Kit (3,000) miles
Postons High performance in tank fuel pump (Not hot wired)
86 ECM & Coil Pack
Boost & Vacum Gauge
No EGR
Throttle Enhancer Calibrator
2 1/2 Crossover pipe
Trans Cooler
2800 Stall Converter
TOYS
1970 Plymouth GTX 440 Six Pack
1969 Plymouth Roadrunner 510 Cubic Inch 10:70's in the 1/4
1993 Z28 LT1 with several Bolt Ons SOON to be sold to purchase a Lightning
Enhanced turbo
160 Stat
390 gears
Home ported heads
Blue Tops
93 Postons Chip
86 ECM & Coil Pack
Boost & Vacum Gauge
No EGR
Trans Cooler
TOYS
