Fuel Pressure!
cesarp
84 Hot Air.
I just tested my fuel pressure at it reads 32PSI in PARK. It is steady. If I disconect the vacuum line to the fuel pressure regulator it goes up which is normal.
Is 32PSI good ?
My car has 100,900 original miles and the engine & transmission are original. Fuel pump is also original.
Goes up to what?
Originally posted by cesarp
But mine only read 32 PSI..... is this ok ?
YOUR not telling everything, GOES UP TO WHAT pressue with the vacuum line off at IDLE ?
DO you have a 233, 237, or an adjustable regulator,
Adjustable regulator is MANADANTORY when turning up the boost
