Okay, I was reading the DIY instructions and noticed this method of wiring the relay: Pole #86 goes to fuel pump jumper which prevents the system from activating unless the fuel pump is running. Is this necessary?
If so, does anyone know, on a hotair car, is the green plug that is just sitting there on the driver's side/front of the engine near/under the coilpack, the fuel pump jumper? This would be probably beneath the alternator on a 86/87. I think it is, but just wanted to verify.
Also, with this method of wiring, is it an issue to use a mityvac to adjust turn on setting on hobbs switch? Do you have to do it when the car is running?
The way mine is wired now, Im using ign pwr, not pwr only when the fuel pump is on, so adjusting is a no brainer. just turn key, pump the mityvac, and watch turn on light and boost gauge to see where hobbs switch is set at.
P.S. This jumper wire gives 12V when car is running/fuel pump is on, right?
