Originally posted by Ken Cunningham
What do you mean "shorting out"? What are the symptoms?
I have been chasing down a 'hard start' condition that has been with me for about 6 mos. Intermittently, my fuel pump will either not cycle on at all, or will just barely get a tickle of power at key on. Not enough to pack the fuel line with fuel. I replaced my relay under the hood with a brand new GM one, replaced my hot wire relay in the trunk, and took out my kill switch to try to clean up the power back to the pump. Still no better.
Then I got a little smarter and tried to be systematic about it. I ran a pair of wires back to the trunk so I could monitor the power on a little digital voltmeter I now keep on the console. 1st, I connected the power monitor wire to the hot wire after both relays, just before the wire exits the trunk to the pump harness. I noticed that, intermittently, I would show no voltage at key on. That finding eliminated the fuel pump as my source of problem. 2nd, I moved the power monitor wire to the trigger line (in my hot wire set up, this is the original fuel pump power line). That also shows an occasional lack of power, exonerating my hot wire relay. Next I should attach my volt meter to the power going into the under-the-hood fuel pump relay. But because it is a new relay, I by-passed that step and swapped in a new (used) ECM. Other people on this board have reported that a bad ECM can cause problems exactly like mine. I just did this today, so have no conclusions yet.
The moral of this too long post: don't be too fast to condemn the fuel pump because there are a lot of links in the chain.
