We have been having some issues with the fuel pressure lately. I have a seperate fuel gauge that I connect to the test port directly. WHen I turn the car on, it shows no fuel pressure, but when I start cranking it climbs up, and then the car starts. Wouldnt this be a bad fuel pump? I put in a new walbro 340 the other day, but havent tested fuel pressure because it was storming when i was finishing up. ANother thing is, what controls the fuel pump? Does it just kick on when the ignition comes on, and then the computer controls it once the engine is started? Im not hearing it when I simply turn the igniton on, which is another reason I think there might be a wiring issue with it. We use to be able to hear it, but it was random. Also, If the computer controls the pump once its on, does the hot wire kit kind of bypass that making it pump ALL the time?
Please help, because I think this might be a problem as to why the car is sputtering at higher rpm due to a lack of fuel.
